Module 6 with Unknown
alsayed
Level 7
Level 7
HI
I Have a 6509 sup720;when i do sh run mod 6
i receive the following:
Model serial Status
Unknown Unknown Unknown
10XS
11 Replies 11
Amit Singh
Hi Ali,
Which module is this. Please let us know the OS running on the switch. Is it CatOS or IOS. Please paste a "show version" from the switch.
-amit singh
HI amit singh!
it is IOS operating system...
10xs
alsayed
Level 7
Level 7
HI
sorry but how can i fix it?
10xs
Hi Ali
Slot 6 should take any linecard for the 6500 with a sup720. Most likely the problem is that the version of software you are running does not support the linecard.
If you identify the linecard which will have it's name on the bottom left of the module eg
WS-X6748-GE-TX
then search for that exact linecard on Cisco website. if you then go to the product page it should telll you the minimum IOS/CatOS you need for that linecard.
if this is not clear post the name of the linecard and your version of software as Amit requested.
Jon
Dear Experts
10xs for all ur replys.
10xs
Amit Singh
Ali,
Please paste the "show version" from the switch and also write the model number of the module that you are trying to put in slot6.
-amit singh
HI AS PER REQUEST:
CORE1#sh mod 6
Mod Ports Card Type Model Serial No.
6 0 Supervisor-Other Unknown Unknown
Mod MAC addresses Hw Fw Sw Status
6 0000.0000.0000 to 0000.0000.0000 0.0 Unknown Unknown Unknown
CORE1#sh ver
IOS (tm) s72033_rp Software (s72033_rp-JK9SV-M), Version 12.2(18)SXD5, RELEASE S
OFTWARE (fc3)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 13-May-05 19:15 by ssearch
Image text-base: 0x4002100C, data-base: 0x42698000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-JK9SV-M), Version 12.2(18)SXD5, RELEASE S
OFTWARE (fc3)
uptime is 40 weeks, 3 days, 20 hours, 38 minutes
Time since SSH-CORE1 switched to active is 40 weeks, 3 days, 20 hours, 37 minute
s
System returned to ROM by reload at 14:31:06 UTC Tue Apr 11 2006 (SP by power-on
System image file is "sup-bootflash:s72033-jk9sv-mz.122-18.SXD5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.2) with 458720K/65536K bytes of m
emory.
Processor board ID SMG0925N2NW
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
8 Ethernet/IEEE 802.3 interface(s)
6 Virtual Ethernet/IEEE 802.3 interface(s)
100 Gigabit Ethernet/IEEE 802.3 interface(s)
8 Gigabit Ethernet/IEEE 802.3 interface(s)
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
CORE1#sh mod 5
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAD092300L8
5 0011.5cab.6620 to 0011.5cab.6623 4.4 8.1(3) 12.2(18)SXD5 Ok
Mod Sub-Module Model Serial Hw Status
5 Policy Feature Card 3 WS-F6K-PFC3B SAD09200ASJ 2.1 Ok
5 MSFC3 Daughterboard WS-SUP720 SAD092104WK 2.3 Ok
Mod Online Diag Status
5 Pass
CORE1#
Hi Ali
If you physically look at the module what type of module is it ?
Jon
That looks like the 2nd Supervisor hasn't booted properly. I suggest you put a console cable into the Sup720 in slot 6 and reset the card (from the active Sup720 or just power reset the whole chassis).
The output from the Sup720 whilst it attempts to boot should give you a good idea what the issue is - probably corrupt IOS image or boot variables are not set. Take a look here:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa1.shtml#s720recover
Andy
Hello Experts
it is WS-SUP720-3B
plz help
10XS
Ali,
It seems like your Sup engine is not booted properly. There is some issue with the Sup engine. Please connect a console to it and see if it is at rommon status. Please check the link below for recovering it:
HTH,
-amit singh
