Module Failed SCP dnld Cisco 6513
moghadasi_ha
Hi ,I have a Cisco catalyst 6513 with sup720-3bxl and WS-X6724-SFP modules , the switch was working fine until yesterday ,but after a maintenance the modue WS-X6724-SFP failed to bring online , the error code is (Module  Failed SCP dnld) does it mean the module has hardware problem or i need to replace it ?
ios version
s72033-adventerprisek9_wan-vz.122-33.SXH7.bin
show module
Mod Ports Card Type                                             Model
  5    6  Firewall Module                                      WS-SVC-FWM-1
  7    2  Supervisor Engine 720 (Active)                 WS-SUP720-3BXL
  9   24  CEF720 24 port 1000mb SFP                  WS-X6724-SFP
11   24  CEF720 24 port 1000mb SFP                 WS-X6724-SFP
13   48  48 port 10/100/1000mb EtherModule       WS-X6148-GE-TX
Mod MAC addresses                                              Hw              Fw               Sw           Status
  5  0011.2000.d974 to 0011.2000.d97b                     3.2               7.2(1)           4.1(6)         Ok
  7  001a.a22d.5728 to 001a.a22d.572b                     5.7               8.5(2)         12.2(33)SXH7 Ok
  9  0027.0dcb.b464 to 0027.0dcb.b47b                     4.3              12.2(18r)S1  12.2(33)SXH7 Ok
11  0027.0d95.d6a8 to 0027.0d95.d6bf                     4.2               Unknown      Unknown      PwrDown
13  0027.0da5.0058 to 0027.0da5.0087                    7.3               7.2(1)           8.7(0.22)BUB Ok
Mod  Sub-Module                              Model                           Hw         Status
  7  Policy Feature Card 3              WS-F6K-PFC3BXL                1.9     Ok
  7  MSFC3 Daughterboard             WS-SUP720                        3.2      Ok
  9  Centralized Forwarding Card     WS-F6700-CFC                    4.1      Ok
11  Centralized Forwarding Card     WS-F6700-CFC                    4.1      PwrDown
Mod  Online Diag Status
  5  Pass
  7  Pass
  9  Pass
11  Not Applicable
13  Pass
console log files
1d03h: %ONLINE-SP-6-TIMER: Module 11, Proc. 0. Failed to bring online because of timer event
1d03h: %C6KPWR-SP-4-DISABLED: power to module in slot 11 set off (Module  Failed SCP dnld)
show power
system power redundancy mode = redundant
system power total =     3795.12 Watts (90.36 Amps @ 42V)
system power used =      1355.76 Watts (32.28 Amps @ 42V)
system power available = 2439.36 Watts (58.08 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-4000W-INT   3795.12 90.36  OK     OK     on
2    WS-CAC-4000W-INT   3795.12 90.36  OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    WS-C6K-13SLT-FAN2   298.20  7.10  OK
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
5    WS-SVC-FWM-1        171.78  4.09   171.78  4.09  on    on
7    WS-SUP720-3BXL      328.44  7.82   328.44  7.82  on    on
8    (Redundant Sup)       -     -      328.44  7.82  -     -
9    WS-X6724-SFP        125.16  2.98   125.16  2.98  on    on
11   WS-X6724-SFP        125.16  2.98     -     -     on    off (Diagnostic Failure)
13   WS-X6148-GE-TX      103.74  2.47   103.74  2.47  on    on
diagnostic start module 11 test complete
1d18h: %DIAG-SP-6-TEST_RUNNING: Module 11: Running TestLoopback{ID=2} ...
1d18h: %DIAG-SP-3-TEST_FAIL: Module 11: TestLoopback{ID=2} has failed. Error code = 0x16
1d18h: %DIAG-SP-6-TEST_RUNNING: Module 11: Running TestTxPathMonitoring{ID=3} ...
1d18h: %DIAG-SP-6-TEST_OK: Module 11: TestTxPathMonitoring{ID=3} has completed successfully
1d18h: %DIAG-SP-6-TEST_RUNNING: Module 11: Running TestL3VlanMet{ID=5} ...
1d18h: %DIAG-SP-3-DIAG_RUNNING: Module 11: Diagnostic is currently running
1d18h: %DIAG-SP-3-TEST_FAIL: Module 11: TestL3VlanMet{ID=5} has failed. Error code = 0x1C
1d18h: %DIAG-SP-6-TEST_RUNNING: Module 11: Running TestIngressSpan{ID=6} ...
1d18h: %DIAG-SP-3-TEST_FAIL: Module 11: TestIngressSpan{ID=6} has failed. Error code = 0x1C
1d18h: %DIAG-SP-6-TEST_RUNNING: Module 11: Running TestEgressSpan{ID=7} ...
1d18h: %DIAG-SP-3-TEST_FAIL: Module 11: TestEgressSpan{ID=7} has failed. Error code = 0x16
1d18h: %DIAG-SP-6-TEST_RUNNING: Module 11: Running TestFirmwareDiagStatus{ID=10} ...
1d18h: %OIR-SP-3-PWRCYCLE: Card in module 11, is being power-cycled off (Diagnostic Failure)
1d18h: %C6KPWR-SP-4-DISABLED: power to module in slot 11 set off (Diagnostic Failure)
1d18h: %DIAG-SP-3-TEST_FAIL: Module 11: TestFirmwareDiagStatus{ID=10} has failed. Error code = 0x7A
Raju Sekharan
That points to a Hardware failure
You need to repalce it
Raju
Thanks for your soon reply
You are welcome
Raju
