Module-Type Unkown Card
sivakondalarao
We have 6006 switch with WS-X6K-SUP1A-2GE and WS-F6K-MSFC2.
Cat OS is 6.4(20)
But I am getting error message
Module Type Unknown Card, Status power-bad.
When module is removed and inserted I have seen console message
APGBIC> (enable) failed to read serial eeprom of linecard in slot 6.
Can I have any suggestions on this?
There is redundant power supply 1330watts.
SKRAO
6 Replies 6
ankbhasi
Hi SKRAO,
Which card is giving this error message? Can you post the model number?
I believe the card which is giving this error message is not supported by the image which you are running on your supervisor. Second reason could be that its a bad hardware also.
Just most the model number of card?
Ankur
Hi SKRAO,
I have already encountered the similler problem before, This is a Modules Hardware Problem.
Danny
Hi Ankur,
Part Model Number is WS-X6324-100FX-MM. Which is supported line card in 6006 with minimum
CatOS 5.3 and recommended 6.4(11)
SKRAO
Hi Skrao,
As you already have the supported image on sup remove and reinsert the module which I believe you have already done. If this message appears again, reset the switch.
If the switch is still unable to read the EEPROM, its a bad hardware then.
Ankur
Ankur,
Thanks for your reply. I have tried reseating, resetting and placing in another slot. But same result.
Previous card given same problem. This is new module, giving same problem. I don't have spare 6006 to test the module.
SKRAO
Hi SKRAO,
Can you try resetting the complete switch if possible?
Also if possible post the "sh mod" , "sh env" and complete error messgae with with % and all.
Ankur
