monitor capture on calatyst 9500 l3 Subinterfaces
maamann
is there a trick on catalyst 9500 L3 Subinterfaces to capture packets via the "monitor capture" feature ?
I tried to capture traffic from Interface
interface TenGigabitEthernet1/0/11.3261
description tport / ETH-10577
encapsulation dot1Q 3261
ip vrf forwarding tport
ip address 192.168.66.1 255.255.255.252
ip pim query-interval 5
ip pim sparse-mode
ip ospf message-digest-key 1 md5 7 43523452345234523452345234523452345234523452345E
ip ospf network point-to-point
ip ospf hello-interval 5
ip ospf 4545451 area 10
end
and i used the commands
9500#show monitor capture TEST para
monitor capture TEST interface TenGigabitEthernet1/0/11 OUT
monitor capture TEST interface TenGigabitEthernet1/0/11.3265 OUT
monitor capture TEST class-map class-default
monitor capture TEST buffer size 100
monitor capture TEST limit pps 10000
9500#
used the interfaces in any variation , tried the vlan number as capture interace ,  tried some other match criteria and ANY as well, but it willnot capture my packets.
If i use a Switchport trunk interfaces everyting works fine. Is there a limitation for L3 Sub-Interfaces or something else ?
Hi @maamann
 The problem is related to the VRF
"Neither VRFs, management ports, nor private VLANs can be used as attachment points."
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-6/command_reference/b_166_9500_cr/b_166_9500_cr_chapter_01001.html
Hi Flavio
yes , but i don´t use the vrf as a source, the Interface like i would interpret the doc like this.
monitor capture TESt interface vrf tport
that captures everyting from the vrf to the buffer.
And on the other hand i would expect that the capture is working on the Main interface beause , this one sees only the L2 Dot1q packets and knows nothing from the vrf.
a classical monitor session is working in this case , so i would assume that it works with monitor capture as well  because i can not Imagine that cisco uses to different processes to send packets to the destination if capture monitor is used or monitor session ...... is used
The doc states attachement not source.   I would try to remove the VRF just to make sure.
