2960 configuration
gilcas
Community Member
Hi, got my hands on a Catalyst 2960 plus. I want to set it up for my home network. 24 port btw. I can setup login and secrets and management port. All good so far. I setup a couple of vlans one for network and one for PoE cameras. The question is, once I have created the vlans how do I get the switch to assign the fastethernet ports to the vlans? Thanks, oh yeah an total novice with Cisco switches
6 Replies 6
Hi @gilcas
 You need to get in the port config and run the command
conf t
 Interface fastethernet  x/x
switchport mode access
switchport access vlan X
b.winter
Why do you post this question in the Collaboration forum? It has nothing to do with Collab^^ There is a specific forum for networking!!
he is new, @gilcas  please label your post with correct label and correct category
for you Q
answer is
interface range fa0/x - y
switchport access vlan x
that it
thanks
MHM
What has "new" to do with the fact, that someone cannot select the correct forum?
M02@rt37
Hello @gilcas,
Create the VLANs: Use the 'vlan' command followed by the VLAN number to create each VLAN. For example, to create VLAN 10 for your network and VLAN 20 for your servers, you would enter the following commands:
vlan 10
name Network
vlan 20
name Servers
Assign access ports to VLANs: Access ports are the FastEthernet ports on the switch that connect to end devices. To assign an access port to a VLAN, use the 'interface' command followed by the interface number, and then specify the VLAN using the 'switchport access vlan' command. For example, to assign FastEthernet port 1 to VLAN 10 and FastEthernet port 2 to VLAN 20:
interface FastEthernet 1
switchport access vlan 10
interface FastEthernet 2
switchport access vlan 20
Configure the uplink port: If you have an uplink port connecting to another network device (e.g., a router), you can assign it to a VLAN as well. Use the same 'interface' command followed by the interface number and then specify the VLAN using the 'switchport mode trunk' command.
interface GigabitEthernet 1/0/1
=> Save the configuration using the 'write' or 'copy running-config startup-config' command. This ensures that the changes persist after a reboot.
Best regards
Joseph W. Doherty
BTW, you have a way to route between your VLANs?
