Monitor session limit exceeded.
Brent Rockburn
Level 6
Level 6
I'm trying to get the traffic going accross a vlan interface to be sent to another port(spanning)
I'm getting the following
Cat6513(config)#monitor session 5 source vlan 100
% Local Session limit has been exceeded
why?
Glad to help and learn at same time 🙂
Please remember to use the rating system and mark, so other readers can save time when scanning thru issues.
Sam
6 Replies 6
cisco_lad2004
Level 10
Level 10
How many SPAN sessions do u have at same time ?
Your SUP has probably exceeded its threshold of allowed sessions.
show monitor session all, will give u a summary.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml
Sam
Cat6513#sh monitor session all
Session 1
Type : Local Session
Source Ports :
Both : Gi9/1,Gi9/7-9,Gi10/1-2,Gi10/5,Gi10/10
Destination Ports : Gi9/2
Session 2
Source Ports :
Both : Gi9/1,Gi9/8,Gi10/1,Gi10/5
Destination Ports : Gi9/37,Gi10/6
I only have two
Then 2 is the limit.
see below for session limit per SUP type.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/span.html#wp1102614
when testing I get more or less same message.
% This platform allows a maximum of 2 concurrent sessions with RX sources and
% 4 concurrent sessions with TX sources. (Bidirectional sources count as
% both RX and TX; remote VLAN sources count as RX.)
Try removing session you don't need or park it temporarily while you test.
Sam
Thanks for the info, you've been a real help!!
cheers
Sam
Done and done my good man!
