Monitor session - RSPAN - no output
alanchia2000
I am having difficulties with getting RSPAN traffic over my trunk link.
Here's the setup .
PC1 ---Gi1/0/1--- Core Sw -Gi1/0/2---Gi1/0/1--- Access switch ---Gi1/0/2--- PC2
PC3 ---Gi1/0/3--------|
PC 3 is sniffer.
PC1: 192.168.1.1/24
Core switch: 192.168.1.2/24 (Gi1/0/1)
Core Switch: 192.168.2.2/24 (Gi1/0/2)
Access switch: 192.168.2.1/24 (Gi1/0/1)
Access switch: 192.168.3.1/24 (Gi1/0/2)
PC2: 192.168.3.2/24
Cisco IOS 3750
Core sw
Interface Gi1/0/1
no switchport
ip address 192.168.1.2 255.255.255.0
no shut
Interface Gi1/0/2
no switchport
ip address 192.168.2.2 255.255.255.0
no shut
monitor session 1 source remote vlan 999
monitor session 1 destination interface Gi1/0/3
monitor session 2 source interface Gi1/0/1 rx
monitor session 2 destination remote vlan 999
Cisco IOS 3750
Access switch
Interface Gi1/0/1
no switchport
ip address 192.168.2.1 255.255.255.0
no shut
Interface Gi1/0/2
no switchport
ip address 192.168.3.1 255.255.255.0
no shut
monitor session 1 source interface gi1/0/2 rx
monitor session 1 destination remote vlan 999
I'm trying to ping from PC 2 to PC 1. Aparently, it wasn't captured on PC3 for some reason.
Could anyone help look at whether my "monitor session" statements are correctly configured.
Thanks.
22 Replies 22
Ah, ok I see what you are trying to do, I thought you were just monitoring just the one port.
In that case,
monitor session 1 source interface gi 1/0/1
monitor session 1 destination interface gi 1/0/3
Craig
Hi Craig,
I think I have tried the commands you suggested, but the system allowed only either the source interface or source remote span session. What IOS version are you using on your 3750. I don't think I'm using the latest version.
Alan
Does anyone know if the following 3 commands on all Cisco 3750s ? I don't think it works on mine?
That was my bad, you can't combine both RSPAN and an interface in the same monitor session, it is either a RSPAN or not and RSPAN, not both.
Unfortunately I can't think of any other way to get the traffic you are wanting... I'm sure there is something I'm missing from the puzzle, maybe I will hit a eureka moment in the middle of the night :)
Maybe try:
monitor session 1 source int gi 1/0/1
monitor session 1 destination remote vlan 998
monitor session 2 source remote vlan 999
monitor session 2 source remote vlan 998
monitor session 2 destination int gi 1/0/3
You can have as many sources as you want, just a maximum number of 2 sessions, can't mix interfaces with VLAN's, so that meets all of the requirements...
HTH,
Craig
Hi Craig,
Appreciate your help in this matter.
I've tried
But it seems that only 1 source remote vlan was allowed on my Cisco 3750 though. Won't work in my scenario. Does it work over your end?
I've been out of my office for a few days, and my terminal server has been hung up, I'll have someone reset it and see what I can come up with.
Craig
Hi, anyone able to help ?
Thanks in advance.
Hello, appreciate any help :)
