Monitoring Port-Security , Error-Disable and HSRP
james.sabia
I am looking to simply monitor Port-Security , Error-Disable and HSRP. I would like to receive an email when any of these are triggered.
Port Security - Port Is shut down
Err-Disable - Port goes into err-disable state (securedown)
HSRP - When HSRP standyby changes are detected
I need to receive emails with any of the able are triggered. What is the easiest way to do this? I know SNMP is the main option but I have never worked with SNMP and dont understand it too much. Would somebody be able to assist me?
Equipment:
2x Cisco 1921 series routers
3x Cisco 2960 POE switches stacked
John Blakley
You can configure the router with an EEM script that can act on a situation and then perform functions for you automatically. Taking HSRP for exampl, when the state goes from active -> standby, you can then email something to yourself from the router directly:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_52_se/configuration/guide/sweem.html
HTH,
John
* Please rate helpful posts *
HTH, John *** Please rate all useful posts ***
