Monitoring QoS with IP SLA
martin.germano
Hi there, i want to monitoring QoS in a switched network with:
- A lot of 2960 (IOS 12.2(55)SE8) and
- 1 Layer 3 core switch 3560 (IOS 12.2(55)SE8)
I can make the switch as a "responder"
ip sla responder
But a can't make the ip SLA source:
ip sla monitor
(config)#ip sla ?
  <1-2147483647>          Entry Number
  enable                  Enable Event Notifications
  ethernet-monitor        IP SLAs Auto Ethernet configuration
  group                   Group Configuration or Group Scheduling
  key-chain               Use MD5 authentication for IP SLAs control message
  logging                 Enable Syslog
  low-memory              Configure Low Water Memory Mark
  reaction-configuration  IP SLAs Reaction-Configuration
  reaction-trigger        IP SLAs Trigger Assignment
  reset                   IP SLAs Reset
  responder               Enable IP SLAs Responder
  restart                 Restart An Active Entry
  schedule                IP SLAs Entry Scheduling
  slm                     Service Level Management
I new on these, i read some cisco documentation. I´m sorry if it confused
So, with 2960 and 3560 can't monitoring QOS?
Thanks a lot
cadet alain
2960 only supports responder:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swipsla.html
and you need IP Services image to have full feature on 3560:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_58_se/configuration/guide/swipsla.html
Alain
cadet alain
Alain
