Monitoring tool For Cisco Switches
Abdul Azeem
Hi All,
I have installed 2 Core Switches and 9 Access Switches (4960-X,3560-X and 2960-X) in our organisation. Now we are looking for a Monitoring tool.
To monitor the Traffic status, Link status, Quarterly Health Check, etc. for all the switches on a single page.
Can anyone please suggest which Cisco Monitoring Tool will suite our requirement.
Responsses will be highly appreciated.......
Maazeem.
daniel.dib
Level 7
Level 7
Have you had a look at Cisco Prime Infrastructure?
http://www.cisco.com/en/US/products/ps12239/index.html
Are you looking only to monitor Cisco devices or other devices as well? There are other tools available also so it depends on your environment, budget etc.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
if you do not have some money for Cisco Prime. You may try Zabbix, cacti or nagios. All from this is open source. But you must have some Linux/Unix experience.
For collect netflow you may try nfsen. It`s support netflow v9 in some version.
Best regards
Collin Clark
Solarwinds Network Performance Monitor would work too.
http://www.solarwinds.com/network-performance-monitor.aspx
Abdul Azeem
Dear All,
Thanks a lot for your responses, i have gone through Cisco Prime and NPM, it looks great to me now let
my management decide what they want to go for.
Abdul Azeem.
