most specific Switch
ahmedalnajjar
What is the suitable series meet this requirments?
1. Support stackable
2. Support four (4) fiber ports (SFP) as minimum (to support full redundancy with firewall in case of adding new zone.
3. Support AC/DCSupport Ethernet 10/100/1000 ports
4. Ease of Use-"Plug-and-Play" Configuration
5. Support Multicast Application
6. Supports a comprehensive set of security features for connectivity and access control, including ACLs, authentication, port-level security, and identity-based network services with 802.1x and extensions.
7. Supports jumbo frames on the 10/100/1000 configurations for advanced data and video applications requiring very large frames.
8. Supports IPv6
9. Bandwidth aggregation up to 16 Gbps through 10 Gigabit EtherChannel technology
10. 500 VLAN IDs are supported.
11. Support Network Timing Protocol (NTP)
12. Integrated security including (NAC)
13. Advanced quality of service (QoS)
14. Support Web-browser setup
15. Performance:
  • Up to 32 Gbps switching fabric
  • Stack-forwarding rate of 38.7 mbps for 64-byte packets
  • Forwarding rate: up to 6 mbps
  • Up to 256 MB DRAM and 32 MB Flash memory
  • Configurable up to 900 IGMP groups and multicast routes
  • Configurable maximum transmission unit (MTU) of up to 8000 bytes, with a maximum Ethernet frame size of 9018 bytes (jumbo frames) for bridging on Gigabit Ethernet ports, and up to 1546 bytes for bridging and routing on Fast Ethernet ports
16. 110/220 volts.
17. Warranty certified by Sis 98 or by equipment manufacturer
18. Up to 115.2 Kbps for Console/Aux port with DDR capability
19. Support Power Over Ethernet (POE) as option.
mahmoodmkl
Level 7
Level 7
i suggest to go with 3750X series
There is another option?
mahmoodmkl
Level 7
Level 7
u can look into higher series like 4500 but need to consider budget as well
