Moving files within flash
woods8
Couldnt find an appropriate forum topic to post my query but here goes.
How do I move a file located in the root of flash(rwx) to another flash directory(drwx)?
Any advice would be very much appreciated.
pkhatri
Level 11
Level 11
Use something like this:
copy flash: flash:/mydir/filename
Hope that helps - pls rate the post if it does.
Paresh
lgijssel
Level 9
Level 9
Please look at the following URL about handling files on the flash.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_configuration_guide_chapter09186a00800ca54d.html
A direct move of a file using a command will not be possible. Provided that you have enough flash-space, you can however copy a file to a different location and then delete the original.
Leo
copy flash:filename flash:/directoryname
