MPLS Over EThernet Xconnect More than two sides
silviorodrigues
Dears good morning!
I have a Site Headquarters and 2 Customer Sites! The lan network Site Headquarters is: 192.168.0.0/24 Vlan 30 and I need extended this lan to my two sites Costumer A and B.
I trie do this with command below!
int f0/0.30
encapsulatio dot1 30
xconect 2.2.2.2 20 encapsulation mpls
xconect 3.3.3.3 30 encapsulation mpls
The problem is that xconect 3.3.3.3 30 overrides xconect 2.2.2.2 20
for clarity, follow a topology!
Thank alot for your help!
rsimoni
Hi Silvio,
EoMPLS (what you have) is a point to point technology. So you can create pseduwires beetween 2 sites only.
To connect more than 2 locations at L2 you need VPLS which is supported only on some specific platforms with specific hardware.
Have a look at this page to know more about it:
http://www.cisco.com/en/US/partner/products/ps6648/products_ios_protocol_option_home.html
regards,
Riccardo
