MPLS
Hi.
The IOS IP BASE for 1841 support MPLS?
mohammedmahmoud
Level 11
Level 11
Hi there,
No the IP BASE (its an entry level IOS - simplest) won't supports MPLS, you have to get SP, Advanced Services, Enterprise Services or Advanced Enterprise Services.
Take a look at the attached diagram.
HTH, please rate if it does help,
Mohammed Mahmoud.
mohammedmahmoud
Level 11
Level 11
Hi there,
Mohammed Mahmoud.
