MPLS
kumaranchn
Community Member
I need to understand the concepts and configuration for MPLS.Kindly let me know the link which helps me better understanding.
Thanks in advance.
mohammedmahmoud
Level 11
Level 11
MPLS stands for Multi Protocol Label Switching, its a way of switching packets based on labels (fast way of packet switching on backbones, plus the extra available features that it introduces), review this document and it'll supply you with the elementary facts:
http://www.cisco.com/en/US/tech/tk436/tk428/technologies_q_and_a_item09186a00800949e5.shtml
And for more details:
http://www.cisco.com/en/US/tech/tk436/tk428/tsd_technology_support_protocol_home.html
[edit] There is also a fine book that you can really depend on:
Cisco Press MPLS Fundamentals by Luc De Ghein, CCIE No. 1897
HTH,
Mohammed Mahmoud.
Pavel Bykov
Level 10
Level 10
read the documents Mohammed provided, but please beware of it's complexity before deploying it in production environment. Meaning you should really know the purpose of why you want it and be able to understand what is going on.
HI Kumar, [PLS rate if HELPS]
MPLS is a packet-forwarding technology which uses labels to make data forwarding decisions. With MPLS, the Layer 3 header analysis is done just once (when the packet enters the MPLS domain).
In addition to above all the Post, pls refer link below:
PLS RATE if HELPS
Best Regards,
Guru Prasad R
