mqc , class map class-default
sarahr202
Level 7
Level 7
Hi everybody.
Please consider the following config:
R1(config)# class-map MUSIC
R1(config-cmap)# match protocol kazzaa2
R1(Config)# policy-map TSHoot-EXAMPLE
R1(config-pmap)# class MUSIC
R1(config-pmap-c)# police 32000
R1(config)# int s0/0
R1(config-if)# service-policy output TSHOOT-EXAMPLE
My book says cisco created a default class map named class-default which categorizes all the traffic not matched by any defined class maps.
Let say we have some packets carrying e mail traffics. These packets are matched by default class map.  What will happen next?  We dont have any policy defined for these packets matched by default class map so what will happen to these packets?
thanks and have a great day.
John Blakley
Sarah,
Anything that doesn't match a class in a policy map will match the class-default class. (Not seen, but it's configurable.) Anything that matches under the class-default class will get best effort delivery by default, but you can configure fair-queueing and tail drop under this class as well. That helps for traffic that does get put into this class.
HTH,
John
HTH, John *** Please rate all useful posts ***
John Blakley
Sarah,
HTH,
John
Thanks John
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
To expand a little on John's posting, implicit (not explicity defined) class-default behavior will vary a bit based on other explictly defined classes and the IOS version, for example pre-HQF and post-HQF QoS.
