MS-130 switch - WAN positioning
Rady
Frequent Visitor
Frequent Visitor
Hello folks,
I have a case where we have two MS-130 will be facing two ISP connections directly, and the these switches will be connected to L3 devices (non-meraki).
How can I manage these switches assuming that the providers will provide /30 for each WAN connection?.
BlakeRichardson
Meraki Community All-Star
No as long as the LAN you put them on has WAN access.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
JamesT91
MX & Switch - WAN Breakout Switch - Google Slides
Appreciate you said non-Meraki firewalls, but the theory is still the same. You would just need to ensure there is a separate vlan interface that is giving the switches internet access on the LAN side so you can manage them via dashboard.
Rady
Frequent Visitor
Frequent Visitor
Thanks a lot. Does it mean that we need a dedicated port for WAN and another one for LAN/management?
BlakeRichardson
