MS-225 Stacking Help
MisG
Community Member
This question has been answered before but not completely.
I'm looking to learn what cables to buy for stacking MS-225s with the ports in the back. The MA-CBL-40G-1M I read about look like they are too small to fit the ports in the back. The spec sheets reads QSFP+ passive Twinax cable assembly. I'm confused.
Using the MS-225 straight out of the box, what do I need to buy to stack two together, using the ports in the back of the device?
Thanks.
9 Replies 9
aleabrahao
Meraki Community All-Star
The stack on the MS2245 is via QSFP.
https://meraki.cisco.com/pt-br/product/switches/switches-accessories/ma-cbl-40g-3m/
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
Raphael_L
Hi ,
You have the correct part number.
https://meraki.cisco.com/product/switches/switches-accessories/ma-cbl-40g-1m/
  • For use with MS210, MS225, MS250, MS350, and MS410 switches
Prestont
you should be able to use MA-CBL-40G-50CM.
if you reference this page Small-Form Factor Pluggable (SFP) and Stacking Accessories - Cisco Meraki Documentation.
you can see what stacking cables will work.
MisG
Community Member
Thanks, all.
So I will need two of these, yes, as described under Physical Switch Stack Configuration Steps here?
Thanks again.
yes, you will need two of the cables.
and then follow the instructions that you have. it is fairly simple.
aleabrahao
Yes
MisG
Community Member
THANKS!
IvanJukic
Meraki Employee All-Star
Hi @MisG,
As others have mentioned, that cable should be fine. I just wanted to share the stacking guide, as reference, when you are ready to Stack them. Also, if you are planning on stacking two switches togather, you'll need a minimum of 2 stacking cables. This is to ensure a full daisy-chain configuration.
https://documentation.meraki.com/MS/Stacking/Switch_Stacks#Configuring_a_Physical_Switch_Stack
Cheers,
Ivan Jukić,
Meraki APJC
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
MisG
Community Member
Thanks so much 🙂
