MS Alert
I have an alert from my MS saying "Port 25 is not using the same VLAN settings as its connected switchport" but I have the correct VLANs on my trunk ports idk why is this appearing....
Johnny Fernandez
Network & Security Engineer
CCNP | JNCIP-SEC | CMNA
It have gotten fixed without intervention LMAO
Johnny Fernandez
ww^
Meraki Community All-Star
You just corrected it or was it already the same? What does the "raw" info at cdp/lldp say?
CMR
@JohnnyFernandez3317 can you please share the same screenshot of port 49 of the other MS?
If my answer solves your problem please click Accept as Solution so others can benefit from it.
Johnny Fernandez
Qwertyuiopasdfg
Community Member
What is solution for that port number 25
