MSata in ISR4331
e-olsen
Hi!
Background: Trying to verify a MSata installed in ISR4331.. copy more than 30 gig worth of files from usb0: to Harddisk:
Harddisk: shows only 20 Gig, and does not want more data than 20 gig no matter what I do.
Have tried:
-Disks: Kingston 120Gig, Samsung 250Gig
-Versions: 16.5.1b, 16.6.1b, 3.16.6.S, 3.15.3.S (All K9)
-Licenses activated: ipbasek9, appxk9, uck9, securityk9, FoundationsuiteK9, AdvUCSuiteK9
-format Harddisk in router tested, both normal and secure
Have talked to others who have tested this with Samsung 160Gig MSata, and it worked..
Anyone who know if there is something special you need to do for this to work?
Regards.
Espen.
eekman
I'm very unfamiliar with the ISR4331, but I read this thread about it a while back, maybe some info there you can use?
Sorry.
No, that one was for Flash memory upgrade.
My problem is with a MSata SSD Disk.
BR
Espen.
dtoubelis
Same here, ISR4331 running Denali 16.3.6. After installing 250GB mSATA SSD from Samsung, IOS shows that only 20GB are available:
20971520K bytes of SATA hard disk at harddisk:.
Did you find a solution?
