mst best practice?
monodactylus
       I use mst for spanning tree on all of my switches.  I'm setting up a new location differently, and was wondering what was considered the best practice.  Right now all my locations are considered different regions.  However this new location is going to be going over MetroEthernet w/ an extended vlan id, with the intention to use the same ip/subnet scheme in this new area.  Should I be setting up the spanning tree in this new area as a different region, or would it be a best practice to place it in the same region as the ip/subnet that I'm extending to this new location?
Will
Giuseppe Larosa
Hello Will,
if you want to extend IP subnets over the metro ethernet link in some ways you are joining the two sites so I would use the same MST region.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Will,
Hope to help
Giuseppe
Giuseppe,
     Thanks for confirming what I was thinking.
will
