MTU configuration on
Etienne FAVRE
I've got a 2811 router with an HWIC-4ESW EtherSwitch card
Th IOS is c2800nm-advsecurityk9-mz.124-15.T7
I need 3 interfaces on that router so I configured one of the EtherSwitch interface as a switchport access on a vlan interface.
The interfaces configuration is as follow :
interface FastEthernet0/0
ip address 192.168.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
no ip route-cache cef
no ip route-cache
no ip mroute-cache
speed 100
duplex full
no shutdown
interface FastEthernet0/1
ip address 192.168.10.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no ip route-cache
no ip mroute-cache
speed 100
duplex full
no shutdown
interface FastEthernet0/0/0
switchport access vlan 10
speed 100
duplex full
no shutdown
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface vlan 10
ip address 174.1.33.2 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no ip route-cache
no ip mroute-cache
no shutdown
My problem is that on the third interface (based on the vlan 10), I've got a cypher equipment that defines a maximum value of MTU to 1420
How can I configure the MTU value on the interface ?
Whatever the configuration I test ("mtu" command in interface mode, "ip mtu" command in interface mode, "mtu" comman in vlan database ...) I always got the same value of 1500 shown on all interfaces on the "sh interface" command
Thanks for your response
Alen Danielyan
"ip mtu" should be ok.
Try to test it using ping with -f option.
