Bookmark
Subscribe
1021
multicasting.... RP selection
xine xine
Hi !
I would like to know if we have more then one router is annoncing it self as an rp-candidate for the same group of multicast group  which one will be choosen by receiver ?  is the router to which receiver as the lower cost too ?  the source to which have the lower cost to ? higher or lower router IP address within it's annoncement ?
what is the selection process exactly !
thanks a lot !
Reza Sharifi
If multiple ip pim rp-address commands are configured, the following rules apply:
Highest RP IP address selected regardless of reachability: If a multicast group is matched by the access list of more than one configured ip pim rp-address command, then the RP for the group is determined by the RP with the highest RP address configured.
Reza
Reza Sharifi
Reza
Mohamed Sobair
Level 7
Level 7
As Riza mentioned, the RP with the highest IP address is elected as an RP candidiate for that Group.
Mohamed
