MTU on switch between two routers
asus zowey
i have the following topology
R1--- SW----R2
if i configure R1 & R2 with MTU 2000 and the L2 Switch has a maximum MTU of 1500.
what happens for the packet flow in this scenario ?
atuljain118
It will not make any difference ... Only thing that need to take care is your L3 device in this case router must have same MTU size ... Packet will flow from origin and collect at the end ie. router to router ... End checksum value will be matched. Router (1476 mtu ) >>> switch >>> router (1476)
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I believe the switch will drop ingress frames that are bigger than its MTU.
