Mulitcasting issues
Kurt Warner
                   Ok i am seeting up SCCM server (10.1.1.37) for my work place and multicasting the images was one of the main feture requests i got. I have it up and running but it is not running well.  i Have 4 sites all connected via a static route over fiber.  One the main sites router , its a 6509 that say basically if the traffiic goes to the internet send it out the gateway of last resport( which goes to an internet facing 6509) .  Anything that internal 10.x.x.x figure where it goes and send it there. When it was running the other day and one system had an error all of the traffic to the internet was slowed ...a lot. IM trying to figure out why im getting - numbers in my rate, when the server is directly connected to the switch it self.
on the internal router lets call it 10.1.1.253 here are my multicast settings
ip flow-cache timeout active 1
ip multicast-routing
no ip domain-lookup
ip domain-name
ip name-server 10.x.x.x.
ipv6 mfib hardware-switching replication-mode ingress
mls ip multicast flow-stat-timer 9
no mls flow ip
no mls flow ipv6
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos map ip-prec-dscp 0 8 16 26 32 46 48 56
mls qos
no mls acl tcam share-global
mls cef error action freeze
ip pim rp-address 10.1.1.253
sample vlan is this
interface Vlan5
ip address 10.1.5.253 255.255.255.0
ip helper-address 10.1.1.11
ip pim sparse-dense-mode
no ip mroute-cache
end
on all the other routers i also have
ip pim rp-address 10.1.1.253.
When my multicast is running from the sccm i ran 3 commands
show ip mroute active
Active IP Multicast Sources - sending >= 4 kbps
Group: 239.0.0.102, (?)
   Source: 10.1.1.37 (?)
    Rate: -3566 pps/42506 kbps(1sec), 42506 kbps(last 0 secs), 0 kbps(life avg)
show ip mroute count
IP Multicast Statistics
19 routes using 9790 bytes of memory
10 groups, 0.90 average sources per group
Forwarding Counts: Pkt Count/Pkts per second/Avg Pkt Size/Kilobits per second
Other counts: Total/RPF failed/Other drops(OIF-null, rate-limit etc)
Group: 233.89.188.1, Source count: 0, Packets forwarded: 0, Packets received: 0
Group: 239.255.255.254, Source count: 0, Packets forwarded: 0, Packets received:
Group: 239.255.255.253, Source count: 1, Packets forwarded: 15, Packets received
: 24
  RP-tree: Forwarding: 5/0/127/0, Other: 5/0/0
  Source: 10.10.1.14/32, Forwarding: 10/0/120/0, Other: 19/9/0
Group: 239.255.255.250, Source count: 1, Packets forwarded: 8, Packets received:
200788
  RP-tree: Forwarding: 8/0/255/0, Other: 8/0/0
  Source: 10.1.1.100/32, Forwarding: 0/-1/0/0, Other: 200780/90742/110038
Group: 239.0.0.102, Source count: 1, Packets forwarded: 0, Packets received: 722
110
  RP-tree: Forwarding: 0/0/0/0, Other: 0/0/0
  Source: 10.1.1.37/32, Forwarding: 0/-3566/0/42506, Other: 722110/26/722084
Group: 224.0.1.40, Source count: 0, Packets forwarded: 0, Packets received: 0
Group: 224.0.1.60, Source count: 0, Packets forwarded: 0, Packets received: 0
Group: 239.255.219.45, Source count: 0, Packets forwarded: 0, Packets received:
Group: 239.1.1.5, Source count: 1, Packets forwarded: 0, Packets received: 9
  Source: 10.10.12.200/32, Forwarding: 0/0/0/0, Other: 9/0/9
Group: 239.1.1.2, Source count: 5, Packets forwarded: 0, Packets received: 0
  Source: 10.10.12.201/32, Forwarding: 0/0/0/0, Other: 0/0/0
  Source: 10.10.12.202/32, Forwarding: 0/0/0/0, Other: 0/0/0
  Source: 10.10.12.203/32, Forwarding: 0/0/0/0, Other: 0/0/0
  Source: 10.10.12.204/32, Forwarding: 0/0/0/0, Other: 0/0/0
  Source: 10.10.12.207/32, Forwarding: 0/0/0/0, Other: 0/0/0
show ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report, Z - Multicast Tunnel
       Y - Joined MDT-data group, y - Sending to MDT-data group
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 233.89.188.1), 4w2d/00:02:22, RP 10.1.1.253, flags: SJC
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    Vlan1, Forward/Sparse-Dense, 5d02h/00:02:31
(*, 239.255.255.254), 1w6d/00:03:12, RP 10.1.1.253, flags: SJC
    Vlan1, Forward/Sparse-Dense, 5d02h/00:03:12
(*, 239.255.255.253), 01:39:07/00:02:33, RP 10.1.1.253, flags: S
    Vlan1, Forward/Sparse-Dense, 01:12:40/00:02:33
(10.10.1.14, 239.255.255.253), 00:39:07/00:01:14, flags: T
  Incoming interface: Vlan922, RPF nbr 192.168.10.2, RPF-MFD
    Vlan1, Forward/Sparse-Dense, 00:39:07/00:02:33, H
(*, 239.255.255.250), 4w2d/00:03:29, RP 10.1.1.253, flags: SJC
    Vlan1, Forward/Sparse-Dense, 5d02h/00:03:29
(10.1.1.100, 239.255.255.250), 2w5d/00:02:54, flags: PJT
  Incoming interface: Vlan1, RPF nbr 0.0.0.0, RPF-MFD
  Outgoing interface list: Null
(*, 239.0.0.102), 00:06:57/00:03:23, RP 10.1.1.253, flags: SJC
    Vlan1, Forward/Sparse-Dense, 00:06:57/00:03:23
(10.1.1.37, 239.0.0.102), 00:06:57/00:02:59, flags: PJT
(*, 224.0.1.40), 4w2d/00:02:51, RP 10.1.1.253, flags: SJCL
    Vlan1, Forward/Sparse-Dense, 5d02h/00:02:51
(*, 224.0.1.60), 5d02h/00:02:54, RP 10.1.1.253, flags: S
    Vlan1, Forward/Sparse-Dense, 5d02h/00:03:09
(*, 239.255.219.45), 1w5d/00:02:59, RP 10.1.1.253, flags: SJC
    Vlan1, Forward/Sparse-Dense, 5d02h/00:02:56
(*, 239.1.1.5), 2w5d/stopped, RP 10.1.1.253, flags: SP
(10.10.12.200, 239.1.1.5), 2w5d/00:01:51, flags: PT
(*, 239.1.1.2), 2w5d/stopped, RP 10.1.1.253, flags: SP
(10.10.12.201, 239.1.1.2), 2w5d/00:01:51, flags: P
  Incoming interface: Vlan922, RPF nbr 192.168.10.2, Partial-SC
(10.10.12.202, 239.1.1.2), 2w5d/00:01:51, flags: P
(10.10.12.203, 239.1.1.2), 2w5d/00:01:51, flags: P
(10.10.12.204, 239.1.1.2), 2w5d/00:01:51, flags: P
(10.10.12.207, 239.1.1.2), 2w5d/00:01:51, flags: P
Kurt Warner
Anyone have any ideas?
What was the error? Was it on the switch? Did you check CPU levels?
Your output looks fine - only thing I recommend changing is the mroute-cache - it must be enabled.
Also, please provide the output from 'show ip pim interface count'
