Mult VLAN
manjit_raulo
Whenever configuring a port as trunking & selecting the port to access a particular vlan,we have a option as multi vlan .
What is multi vlan ??
For what purpose we will select the option as "switchport multivlan" while configuring a particular interface.
Edison Ortiz
Please refer to the documentation:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc5/cli/clicmds.html#wp1058013
You are dealing with a very OLD command.
Edison.
Reza Sharifi
Manjit,
I think you'll find that "switchport multi" isn't supported on the more-modern hardware platforms.
So, use switchport mode trunk instead
Reza
