Multicast between VLAN's
shamg1974
Level 3
Level 3
Hello all,
I have Panasonic projectors in one subnet and laptops in another subnet. I'm not able to reach the projectors from the laptops via the Panasonic Wireless Manager. I can ping them, but that's it. I'm suspecting some kind of multicast issue. I have the following configured on my router:
interface Vlan300  (Projectors)
description Legacy Network
ip address 172.21.7.1 255.255.224.0
ip helper-address 172.21.0.222
ip pim sparse-dense-mode
interface Vlan11 (laptops)
description Wireless Students
ip address 10.200.11.1 255.255.255.0
From what i've read, I don't need an RP. I've attached my config if it helps.
Any help is greatly appreciated.
Bobby Grewal
7 Replies 7
Dirk Woellhaf
Level 3
Level 3
first question is:
- are you sure that the traffic is routable? Having at least TTL >2?
And by checking your config I´ve seen a 5508 WLC, which brings up the following questions:
- Are your clients wireless clients?
- If wireless, did you enable MC-Routing on the Controller?
regards,
    Dirk
(Please rate if helpful)
regards, Dirk (Please rate if helpful)
Dirk,
Yes traffic is routable.TTL is greater than 2, however. More like 253.Global Multicast mode is enabled on the controllers.
Bobby
Correction...Multicast messaging isn't enabled on the WLC.
STPCS_MDFB_Core#sh ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group
       V - RD & Vector, v - Vector
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.255.255.254), 01:02:08/00:02:13, RP 172.21.7.1, flags: SJC
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    Vlan300, Forward/Sparse-Dense, 00:54:10/00:02:13
(*, 239.255.255.253), 01:02:16/00:02:16, RP 172.21.7.1, flags: SJC
    Vlan300, Forward/Sparse-Dense, 00:54:12/00:02:16
(*, 239.255.255.250), 01:02:16/00:02:16, RP 172.21.7.1, flags: SJC
    Vlan300, Forward/Sparse-Dense, 00:54:12/00:02:11
    Vlan12, Forward/Sparse-Dense, 01:02:16/00:02:12
    Vlan11, Forward/Sparse-Dense, 01:02:16/00:02:16
(*, 239.1.2.3), 01:03:02/stopped, RP 172.21.7.1, flags: SJC
    Vlan300, Forward/Sparse-Dense, 00:54:11/00:02:13
    Vlan5, Forward/Sparse-Dense, 01:03:02/00:02:52
(10.200.5.11, 239.1.2.3), 00:59:24/00:02:57, flags: T
  Incoming interface: Vlan5, RPF nbr 0.0.0.0
    Vlan300, Forward/Sparse-Dense, 00:59:24/00:02:13
(*, 239.1.2.4), 01:03:02/stopped, RP 172.21.7.1, flags: SJC
    Vlan5, Forward/Sparse-Dense, 00:01:13/00:02:54
(10.200.5.12, 239.1.2.4), 00:59:23/00:02:57, flags: PT
  Outgoing interface list: Null
(*, 235.80.68.83), 01:02:15/00:02:16, RP 172.21.7.1, flags: SJC
    Vlan300, Forward/Sparse-Dense, 00:54:02/00:02:16
(*, 224.3.4.5), 01:02:13/stopped, RP 172.21.7.1, flags: SJC
    Vlan300, Forward/Sparse-Dense, 00:54:04/00:02:18
(172.21.0.248, 224.3.4.5), 00:59:08/00:02:11, flags: PT
  Incoming interface: Vlan300, RPF nbr 0.0.0.0
(*, 224.0.1.24), 01:02:12/00:02:08, RP 172.21.7.1, flags: SJC
    Vlan300, Forward/Sparse-Dense, 00:54:12/00:02:08
(*, 224.0.1.1), 01:02:15/00:02:08, RP 172.21.7.1, flags: SJC
(*, 224.0.1.60), 01:02:19/00:02:08, RP 172.21.7.1, flags: SJC
    Vlan300, Forward/Sparse-Dense, 00:54:15/00:02:08
(*, 224.0.1.40), 01:03:05/00:02:14, RP 172.21.7.1, flags: SJCL
    Vlan300, Forward/Sparse-Dense, 00:54:19/00:02:14
STPCS_MDFB_Core#
Ok,
what does your MC-Routing-Table look like? (show ip mroute)
regards,
    Dirk
So which is the mc-group for the panasonic-stuff?
Is there a Client requesting the group (show ip igmp groups)?
regards,
    Dirk
The projectors are on vlan 300. I believe the group is:
239.1.2.3 is what is configured on the WLC as the multicast group IP.
Here is show ip igpm groups:
STPCS_MDFB_Core#sh ip igmp groups
IGMP Connected Group Membership
Group Address    Interface                Uptime    Expires   Last Reporter   Group Accounted
239.255.255.254  Vlan300                  1w1d      00:02:35  172.21.0.222
239.255.255.253  Vlan300                  36w3d     00:02:30  172.21.7.99
239.255.255.250  Vlan12                   02:39:58  00:02:34  10.200.12.2
239.255.255.250  Vlan11                   4d04h     00:02:30  10.200.11.2
239.255.255.250  Vlan300                  1y5w      00:02:26  172.21.3.211
239.1.2.3        Vlan300                  1w3d      00:02:26  172.21.4.254
239.1.2.3        Vlan5                    1y5w      00:02:27  10.200.5.66
239.1.2.4        Vlan5                    00:23:05  00:02:30  10.200.5.12
235.80.68.83     Vlan300                  34w2d     00:02:36  172.21.0.224
224.3.4.5        Vlan300                  1y5w      00:02:28  172.21.0.248
224.0.1.24       Vlan300                  1w1d      00:02:29  172.21.0.222
224.0.1.1        Vlan300                  1d13h     00:02:26  172.21.0.249
224.0.1.60       Vlan300                  13w5d     00:02:26  172.21.5.48
224.0.1.40       Vlan300                  1y5w      00:02:27  172.21.7.1
STPCS_MDFB_Core#
