Multicast filtering better at L-2 or L3 ?
fsebera
Level 4
Level 4
Anyone have experience with multicast filtering features as
IP IGMP Filter   or   IP IGMP Max-groups features in a layer-2 switching environment or
in a layer-3 environment   IP IGMP ACL   or   IP IGMP Limit features on a router?
Is it better to filter on ingress user ports on a layer-2 switch or utilize layer-3 filtering techniques on the router or BOTH?
Is some other method better?
Our switches are 2960, 3750 and 4500 series.
What we're doing - I'm starting to roll out multicast (PIM Sparse-mode only, for now) across the MPLS WAN (~300 sites) using redundant auto-RPs via Anycast and group dissemination between mapping agents via MSDP.  Multicast groups will consist of a /28 group range (239.255.0.0/28) so our multicast setup will be considered small. Each LAN environment is configured to use IGMPv3 on VLC clients. Since this may well end up being a 1 man show, I would like to take as many up front precautions as I can -  perhaps ease up on the restrictions later on.
So far I have noticed many local devices continue to solicit for their group addresses I.E. HP at 224.0.1.60, MS SSDP at 239.255.255.250, Novell SLP at 224.0.1.22 etc. etc. etc. I don't want surprises to complicate this implementation. I cannot force the support staff to correct these issues so I have to work around 'em - with filtering I guess!!!
THANKS for sharing
Frank
Layer-2
IP IGMP filter
IP IGMP Max-groups
Layer-3
IP IGMP Access-Group (standard or extended)
IP IGMP Limit
fsebera
Level 4
Level 4
Update....... just in case you cared :
The filtering techniques above appears to be only supported by IGMP version 2, which is fine. VLC operates with IGMP version 2 also. However Layer-2 filtering seems to be crap. Many issues.
Only tested on the Cisco 2960 switch as this model of switch is most prevalent within our environment.
IGMP filtering at layer 3 however is much easier and things respond immediately. Limiting the number of groups works as expected. Filtering via ACL works very well too. Response is immediate
Frank
