Multicast flooding with IGMP Snooping
JF
I have a VSS with 2x 4500x (Release 3.4.0SG ED) and 3750x (Release 12.2.58.SE2) access switches.
Two multicast streamers are connected to core switches and boxes are connected to access switches.
IGMP Querrier is configured on Core and fast-leave on access. All equipment are in the same VLAN so i didn't configure multicast routing on the SVI.
On the core switch, i see all the groups (90x) who are diffused by the streamers on the interface of the streamer.
But when i do a wireshark capture on the etherchannel who is going to my access switches, i see all groups diffused!
I don't understand why multicast traffic are diffused on link who not belong to the IGMP group.
Do you have an idea ?
Some commands of the core switchs :
RSW01-MDF1#show ip igmp snooping groups vlan 300
Vlan      Group                    Version     Port List
300       239.1.1.12               v2          Te1/2/4
300       239.1.1.21               v2          Te2/2/2
300       239.1.1.23               v2          Te2/2/2
300       239.1.1.27               v2          Te2/2/2
... (x90)
RSW01-MDF1#show int | i Des|bits
  Description: To_SW01-05_1:Po24
  5 minute input rate 5094000 bits/sec, 868 packets/sec
  5 minute output rate 43043000 bits/sec, 4422 packets/sec
RSW01-MDF1#sh ip igmp snooping vlan 300
Global IGMP Snooping configuration:
IGMP snooping                : Enabled
IGMPv3 snooping              : Enabled
Report suppression           : Enabled
TCN solicit query            : Disabled
TCN flood query count        : 2
Last member query interval   : 1000
Vlan 300:
CAPWAP enabled                      : Disabled
IGMPv2 immediate leave              : Disabled
Explicit host tracking              : Enabled
Multicast router learning mode      : pim-dvmrp
CGMP interoperability mode          : IGMP_ONLY
RSW01-MDF1#show run
ip igmp snooping querier
interface Port-channel24
switchport
switchport trunk allowed vlan 5,10,100,120,200,210,300,410,430,450,580,600,610
switchport mode trunk
load-interval 30
ip dhcp snooping trust
interface TenGigabitEthernet1/1/15
udld port aggressive
channel-group 24 mode active
service-policy output EGRESS-QUEUING
interface TenGigabitEthernet2/1/15
interface Vlan300
description IPTV
ip vrf forwarding IPSERVICES
ip address 10.3.3.254 255.255.252.0
no ip redirects
no ip unreachables
no ip proxy-arp
Thanks.
Hi Bob,
Did you ever find out the cause and/or resolution to this issue?
We seem to be experiencing the same thing...
It was an instability of the spanning-tree (a trunk interface in the network was flapping and generate TCN every minutes). An IGMP snooping-enabled switch floods multicast traffic to all ports in a VLAN when a spanning-tree Topology Change Notification (TCN) is received.
Usefull CLI to check stp stability :
Router#sh spanning-tree vlan 300 det | in ieee|from|occur|exec
VLAN0300 is executing the rstp compatible Spanning Tree protocol
  Number of topology changes 208 last change occurred 00:00:13 ago
          from Port-channel36
Hope this help
HELLO JF ,
we have mulicast streamers ( video wall ) , for that we have enable the IGMP snooping and querier on the switch ( cisco 4506 E ) not on the VLAN .
We have one vlan only , when this multicast streamer is connected to the switch it make all other device very slow and even loss of packets .
we need to kniow what can be done to solve this issue .
i have attached the wireshark output and the snapshot for the ping
https://drive.google.com/open?id=14jX9PcxwzmdC2upydX-9v5rKtgh_jS1x
