multicast issue
always.an.answer
Frequent Visitor
Frequent Visitor
I have 2 sources that we get out multicast feed from, they are not the same feeds they both provide different videos and they come from a different source but when I have both interfaces on for both sources of multicast feeds the videos bleed into each other I am not sure what is causing this I have been banging my head on the table for some time now, I have no clue if this is a lan issue or something completely different has anyone ever experienced this?
Hello
What mode of MC are you using ?
res
Paul
Kind Regards
Paul
johnd2310
Level 11
Level 11
What multicast addresses are the 2 feeds using and how do you connect to the 2 sources?
John
**Please rate posts you find helpful**
they are using two different devices and two completely different ip schemes for security reasons I cant give them out, but they are not even close to being in the same subnet. you can view them both in the same gui interface the problem could be there I was just not sure if anyone has ever ran into this issue
Hello
res
Paul
Kind Regards
Paul
