multicast issues using symantec ghost application over 3850 cisco switch
nagasheshu.2014
Level 2
Level 2
Hi Team,
we have a Symentac Ghost application using which I am trying to do a multicast of an image to some users who are on same switch.
However, it is unsuccessful. the same is successful over different site 3850 switch. I am unsure if there is any IGMP/multicast configuration in the switch is missing or incorrect. Need your expertise advice asap.
when I initiate transfer to 3 users at once, the ports they are directly on are flapping, I enabled debug on IGMP and have seen below logs. Not sure what exactly they mean.
001004: *Jul 28 14:48:05.687 CDT: Pvmp Gi2/0/14, VLAN 32, not FWDing
001005: *Jul 28 14:48:05.687 CDT: IGMPSN: group: Deleting client ip on vlan 32
001006: *Jul 28 14:48:05.687 CDT: IGMPSN: mgt: Vlan 32, port Gi2/0/14 port_id 78 in non-fwd mode
001007: *Jul 28 14:48:05.687 CDT: Pvmp Gi2/0/14, VLAN 16, not FWDing
001008: *Jul 28 14:48:05.687 CDT: IGMPSN: mgt: Vlan 16, port Gi2/0/14 port_id 78 in non-fwd mode
001009: *Jul 28 14:48:06.679 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/14, changed state to down
UV-FLORA104-3850#
001010: *Jul 28 14:48:07.681 CDT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/14, changed state to down
UV-FLORA104-3850#
001011: *Jul 28 14:48:07.683 CDT: IGMPQR: vlan_id 32: PIM enable state change DISABLED received in Disabled state
001012: *Jul 28 14:48:07.683 CDT: IGMPQR: vlan_id 32: cannot be oper enabled due to: IGMP switch querier is disabled on this vlan
UV-FLORA104-3850#
001013: *Jul 28 14:48:12.790 CDT: Pvmp Gi2/0/14, VLAN 16, FWDing
001014: *Jul 28 14:48:12.790 CDT: IGMPSN: mgt: Vlan 16, port Gi2/0/14 port_id 78 in fwd mode
001015: *Jul 28 14:48:12.790 CDT: Pvmp Gi2/0/14, VLAN 32, FWDing
001016: *Jul 28 14:48:12.790 CDT: IGMPSN: mgt: Vlan 32, port Gi2/0/14 port_id 78 in fwd mode
UV-FLORA104-3850#
001017: *Jul 28 14:48:14.771 CDT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/14, changed state to up
001018: *Jul 28 14:48:15.771 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/14, changed state to up
Please find some IGMP commands output if that helps.
UV-FLORA104-3850#sh ip igmp snooping groups
Load for five secs: 5%/1%; one minute: 6%; five minutes: 6%
Time source is NTP, *12:01:17.731 CDT Sat Jul 29 2017
Vlan Group Type Version Port List
UV-FLORA104-3850#
UV-FLORA104-3850#sh ip igmp snooping mrouter
Time source is NTP, *12:01:44.313 CDT Sat Jul 29 2017
Vlan ports
10 Te1/1/4(dynamic)
UV-FLORA104-3850#
UV-FLORA104-3850#sh ip igmp snooping querier
Load for five secs: 4%/1%; one minute: 6%; five minutes: 6%
Time source is NTP, *12:02:06.404 CDT Sat Jul 29 2017
Vlan IP Address IGMP Version Port
10 10.10.61.31 v2 Te1/1/4
UV-FLORA104-3850#
UV-FLORA104-3850#sh ip igmp snooping vlan 32
Load for five secs: 14%/6%; one minute: 8%; five minutes: 7%
Time source is NTP, *12:05:39.634 CDT Sat Jul 29 2017
Global IGMP Snooping configuration:
IGMP snooping : Enabled
IGMPv3 snooping (minimal) : Enabled
Report suppression : Enabled
TCN solicit query : Disabled
TCN flood query count : 2
Robustness variable : 2
Last member query count : 2
Last member query interval : 1000
Vlan 32:
IGMPv2 immediate leave : Disabled
Multicast router learning mode : pim-dvmrp
CGMP interoperability mode : IGMP_ONLY
UV-FLORA104-3850#
can you please help me, its urgent and my job is at stake. Please let me know if you need more details.
thanks in advance.
7 Replies 7
nagasheshu.2014
Level 2
Level 2
Please help me on this one, thanks!!
Is there some form of multicast enabled by default that's not enabled on the 3650
did you diff the running config that you usually cant see ? that's what I would check first
sh run all
or narrow it down
I see a good bit of igmp enabled that's not on the 3650
#sh run all | i igmp
ip igmp ssm-map query dns
ip igmp snooping report-suppression
no ip igmp snooping tcn query solicit
ip igmp snooping tcn flood query count 2
ip igmp snooping robustness-variable 2
ip igmp snooping last-member-query-count 2
ip igmp snooping last-member-query-interval 1000
ip igmp snooping querier version 2
ip igmp snooping querier query-interval 60
ip igmp snooping querier max-response-time 10
ip igmp snooping querier timer expiry 120
ip igmp snooping querier tcn query count 2
ip igmp snooping querier tcn query interval 10
no ip igmp snooping querier
ip igmp snooping
 ip igmp last-member-query-interval 1000
 ip igmp last-member-query-count 2
 ip igmp query-max-response-time 10
 ip igmp v3-query-max-response-time 10
 ip igmp version 2
 ip igmp query-interval 60
 ip igmp tcn query count 2
 ip igmp tcn query interval 10
 ip igmp version 2
 ip igmp version 2
 ip igmp version 2
 ip igmp version 2
 ip igmp version 2
 ip igmp version 2
 ip igmp version 2
 ip igmp version 2
 ip igmp version 2
 ip igmp version 2
 ip igmp version 2
 ip igmp version 2
 ip igmp version 2
 ip igmp version 2
 ip igmp version 2
 ip igmp version 2
 ip igmp version 2
 ip igmp version 2
3650 just has this
ip igmp snooping
Hi Mark,
Thanks for your response. I am facing issue with 3850 switches, not sure where I mentioned 3650.
I am seeing IGMP enabled on all vlans, whereas VLAN 32 is the one i am struggling with. However, I have tested if it running successfully on other vlans.
when I do "sh run | i igmp", no commands gets listed. This hints IGMP is enabled by default.
hi sorry thought I seen 3650 was still early 🙂
try show run all | I igmp .... this will show you any hidden multicast commands , there are commands on switches and routers not visible unless you select the all
Hi Mark,
Thanks for your response again, it has started working after configuring below command "ip igmp snooping querier"
all happy happy, I am safe for now.
thanks again!!
ah great once its running that's all you need 🙂
jkilleda
Level 6
Level 6
Hello Nagasheshu,
Multicast issues using symantec ghost application over 3850 cisco switch
Use the command "IP IGMP SNOOPING MROUTER" and it will be resolved
