Multicast on a single vlan
sdurn
I need to enable multicast on a single vlan, the multicast sources and receivers are in the same vlan 310 for what I have configure the IGMP snooping on all switches where the multicast servers are connected (and in all switches through wich the transit traffic)   and igmp snooping querier in the interface of level 3 for this vlan310.
We tested this feature with the software SSMPING and have been able to verify that multicast works one way but in the other not, which may be the source of this problem?
the intermediate switches recognizes the correct igmp snooping querier:
CPD#
interface Vlan310
ip address 172.30.7.130 255.255.255.0
ip igmp snooping querier
standby 40 ip 172.30.7.129
SWBL3# show ip igmp snooping querier
Vlan      IP Address        IGMP Version   Port
310       172.30.7.130      v3             Po1
SWBL4#show ip igmp snooping querier
CPD#show ip igmp snooping statistics
  Current number of Statistics entries    : 23
  Configured Statistics database limit    : 32000
  Configured Statistics database threshold: 25600
  Configured Statistics database limit    : Not exceeded
  Configured Statistics database threshold: Not exceeded
Snooping statistics for Vlan310
#channels: 8
#hosts   : 14
Source/Group                    Interface       Reporter        Uptime   Last-Join Last-Leave
0.0.0.0/224.12.12.2             Vl310:Gi3/9     0.0.0.0         2w5d         -     2w5d
0.0.0.0/224.12.12.2             Vl310:Gi7/40    0.0.0.0         2w5d         -     2w5d
0.0.0.0/224.12.12.2             Vl310:Gi8/5     172.31.125.177  2w5d         -     2w5d
0.0.0.0/224.12.12.2             Vl310:Gi8/23    172.31.125.170  2w5d         -     2w5d
0.0.0.0/239.255.2.3             Vl310:Gi9/19    172.30.7.204    5d21h    00:00:52  5d18h
0.0.0.0/224.12.12.2             Vl310:Po35      0.0.0.0         2w5d         -     2w5d
172.30.7.196/232.43.211.234     Vl310:Po4       172.30.7.137    2w5d     01:03:02      -
0.0.0.0/231.121.206.196         Vl310:Po74      172.30.7.199    2w5d     00:00:52  1w2d
0.0.0.0/231.121.212.133         Vl310:Po74      172.30.7.199    2w5d     00:00:52  1w2d
172.30.7.137/232.43.211.234     Vl310:Po209     172.30.7.196    2w4d     01:11:04  01:11:04
thanks in advance.
Amit Singh
Could you please breif a bit about toplogy?. A diagram would help, where are the source located and the receivers..how many sources...etc..
Amit Singh
There is only one sender and a receiver, which must operate in both directions.
Both are connected to the same VLAN but on different Switches:
VLAN 310:
SRV00395 (172.30.7.137) <-> SWBL3TIC (G0 / 3) <-> SWTIC01 - SPACPD_3 <-> SPACPD_1 <-> SPACPD_2 <-> SWBL43 (G0 / 3) <-> CEPSWMET (172.30.7.196)
thanks!
