Multicast on Cisco 3560
Xiucutil1979
Hello, I am looking for help with multicasts on Cisco 3560  - connected directly to streamer and to two L2 switches (2950, 2960), steamer on its own is linux debian and I am using VLC. So multicast is directly streamed into local Vlan 60 and I can clearly see that it arrives on interface of vlan 60 by ACL I have for this reason applied, but there everything ends it is not switched into other vlans. Before I used physical port with no switchport configuration on for streaming and other one for telnet access I could clearly see that multicast traffic goes thourgh, But it doesn't work out with vlans and whole IGMP, PIM infrastructure i builded for it. Is anyone who tried to sort out similar problem willing to share his (her) experience? I am starting to be desperate
Here is shortage of my conf on main 3560
  version 15.2
ip routing
ip multicast-routing distributed
ip sap cache-timeout 60
ip device tracking
ip igmp snooping querier
ip igmp snooping vlan 40 last-member-query-interval 120
ip igmp snooping vlan 50 last-member-query-interval 120
interface GigabitEthernet0/1
switchport access vlan 60
switchport mode access
interface GigabitEthernet0/20
interface GigabitEthernet0/21
no switchport
ip address 192.168.10.200 255.255.255.0
ip access-group zakaz-multi-na-port out
interface GigabitEthernet0/22
no switchport
no ip address
interface GigabitEthernet0/23
switchport mode trunk
interface GigabitEthernet0/24
interface Vlan1
ip address 192.168.20.1 255.255.255.0
ip pim sparse-dense-mode
ip sap listen
interface Vlan40
ip address 40.0.0.1 255.255.255.0
ip igmp join-group 239.0.0.1
ip sap listen
interface Vlan50
ip address 50.0.0.1 255.255.255.0
ip sap listen
interface Vlan60
ip address 60.0.0.1 255.255.255.0
ip pim rp-address 192.168.20.1 acl-rp-multi
ip access-list standard acl-rp-multi
permit 224.0.0.0 15.255.255.255
deny   any
ip access-list extended ipmc-source
permit ip 60.0.0.0 0.0.0.255 224.0.0.0 15.255.255.255
deny   ip any 224.0.0.0 15.255.255.255 log
permit ip any any
ip access-list extended zakaz-multi-na-port
deny   ip 224.0.0.0 15.255.255.255 any
permit ip any any
monitor session 1 source vlan 60
monitor session 1 destination interface Gi0/22
You need to enable pim on all L3 interfaces; make sure have config TTL higher than 1 on VLC; no need for static mroute; do not use 239.0.0.1 group.
HTH,
Lei Tian
daniel.dib
Level 7
Level 7
You haven't enabled PIM on SVI for VLAN 60. It could also be related to mrouter port. Does it work if you have receiver in the Cat 3560? See this document for additional troubleshooting:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008059a9df.shtml
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
Hello, thank you for your reply. As you adviced me I have added
on inr vlan 60 (meanwhile erased ip igmp join-group 239.0.0.1)
and
ip mroute 60.0.0.0 255.255.255.0 60.0.0.2
and trying to receive stream on main L3 switch, in vlan 50, but still nothing, still IGMP for some reason can not find source, these are my logs and thank you in advance.
L3Streamer#debug ip igmp
IGMP(0): Received v2 Report on Vlan50 from 50.0.0.11 for 239.0.0.1
IGMP(0): Received Group record for group 239.0.0.1, mode 2 from 50.0.0.11 for 0 sources
L3Streamer#sh ip igmp snooping mrouter
Vlan    ports
   1    Router
  40    Switch
  50    Switch
  60    Router
L3Streamer#sh ip igmp snooping querier detail
Vlan      IP Address               IGMP Version   Port
1         192.168.20.1                  v2            Router
40        60.0.0.1                        v2            Switch
50        60.0.0.1                        v2            Switch
60        60.0.0.1                        v2            Router
Global IGMP switch querier status
admin state                    : Enabled
admin version                  : 2
source IP address              : 60.0.0.1
query-interval (sec)           : 60
max-response-time (sec)        : 10
querier-timeout (sec)          : 120
tcn query count                : 2
tcn query interval (sec)       : 10
Vlan 1:   IGMP switch querier status
admin state                    : Enabled (state inherited)
admin version                  : 2
tcn query count                : 2
operational state              : Disabled
operational version            : 2
tcn query pending count        : 0
Vlan 40:   IGMP switch querier status
elected querier is 60.0.0.1        (this switch querier)
admin version                  : 2
tcn query count                : 2
operational state              : Querier
Vlan 50:   IGMP switch querier status
admin version                  : 2
tcn query count                : 2
Vlan 60:   IGMP switch querier status
admin version                  : 2
tcn query count                : 2
L3Streamer#sh ip pim int
Address          Interface           Ver/      Nbr       Query  DR     DR
                                             Mode   Count     Intvl    Prior
192.168.20.1     Vlan1              v2/SD    0          30      1       192.168.20.1
60.0.0.1           Vlan60             v2/SD    0          30      1         60.0.0.1
HTH,
Lei Tian
Thank you that was it, you saved me, now is it working even through other devices
