TOPOLOGY MSTP
vpancisco
Hello word,
I'm looking for someone help me to determine the best mutliregion or single ?? topology to set up MSTP
this is my hard switch and vlan topology :
2 Accepted Solutions
No,
Actually the opposite, Interasys for some and Aallied for other so you can split the traffic across several links,
Jcarvaja
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Exactly,
You got it now
Jcarvaja
Julio Carvajal
9 Replies 9
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Normally, from your diagram, would expect root and secondary root to be your two switches, INTRASYS and ALLIED, in the center of your diagram, at they appear to be the center of your topology.
thank you very much
according to u , does this upgrade drawing seams to be a good topology ?
daniel.dib
Level 7
Level 7
It depends on the goal of the topology. All switches belong to same organization? If you create different regions you will have less links forwarding.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
thank you very much
best regards
So you will only have 4 vlans so if running RSPT you will have only 4 instances which does not look bad at all nor memory intensive.
Now if you are lloking to practice or learn about MST just set Interasys as the primary root Switch for some vlans and Allied for others in order to distribute traffic as much as possible.
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
thanks
I want to work with MSTP so as to split vlan traffic as explain in the drawing
so ...
According to you i will put INTERASYS as root for all instances ??
No,
Jcarvaja
Julio Carvajal
Oki
for instance :
i use AaLLIED as root bridge for  vlan 110 and vlan 1 MST 'instances
and the INTERASYS for 22,25 MST instances ?
Exactly,
You got it now
Jcarvaja
Julio Carvajal
