multicast on vrf on 4506 switches
mirehteshamali
Hi experts
we have   a  4600  series  switch and  i am  trying to configure  multicast  inside  a vrf .
  core(config)#ip multicast-routing ?
as  i see we dont  have  support  for   vrf  multicast   right now .
ie   ip multicast-routing vrf  VPNA    command is not available
CORE#show ver Cisco Internetwork Operating System Software IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I5S-M),
Version 12.2(20)EWA4, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport
System image file is "bootflash:cat4000-i5s-mz.122-20.EWA4.bin  ..
is the support  for  multicast  inside   a  vrf  available  for  4506 ?  if  yes  what version  should  i upgrade to  ??
7 Replies 7
mirehteshamali
Gents    i am trying to  find  ip multicast-routing vrf  support  in  command  reference  of  4500 series  images , but  unable to find one
This feature does not seem to be supported on 4500. I could not find it for 4500 in feature navigator and not in the configuration guide either. I saw that it was supported for 3750, 6500, 7600 and so on.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
maxrodri
Hello people,
On the version that you are running at this moment, version 12.2(20)EWA4, multicast routing VRF is not supported, however, looking on the configuration guide for the 4500 I found the command enable after the version 12.2(50)SG:
(Log in is needed):
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/50sg/configuration/guide/vrf.html#wp1063444
Switch(config-vrf)# ip multicast-routing vrf
(Optional) Enables global multicast routing for VRF table.
Check if the version 12.2(50)SG is compatible with the supervisor engine that you have on the 4506 prior to upgrade to the IOS version
hi all
  i think  their  is   documentation error.
i  have  upgraded to
BB1#show ver Cisco  IOS Software, Catalyst 4500 L3 Switch Software  (cat4500-ENTSERVICESK9-M), Version 12.2(54)SG1,
RELEASE SOFTWARE (fc1)  Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2011 by Cisco Systems, Inc. Compiled Thu 27-Jan-11  11:39 by prod_rel_team Image text-base: 0x10000000, data-base:  0x123FB194
  ROM: 12.2(31r)SG2 Dagobah Revision 226, Swamp Revision 34
BB1 uptime is 13 hours, 40 minutes System returned to ROM by  power-on System restarted
at 06:15:00 EST Mon Nov 4 2013 System image  file is "bootflash:cat4500-entservicesk9-mz.122-54.SG1.bin"
This  product contains cryptographic features and is subject to United States  and local country laws governing import, export, transfer and use.  Delivery of Cisco cryptographic products does not imply third-party  authority to import, export, distribute or use encryption. Importers,  exporters, distributors and users are responsible for compliance with  U.S. and local country laws. By using this product you agree to comply  with applicable laws and regulations. If you are unable to comply with  U.S. and local laws, return this product immediately.
A summary of U.S.  laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html  If you require further assistance
please contact us by sending email to export@cisco.com
cisco WS-C4506 (MPC8245) processor (revision 4) with 524288K bytes of  memory
. Processor board ID FOX11090SLF MPC8245 CPU at 400Mhz, Supervisor
V Last reset from Abort 147 Virtual Ethernet interfaces 44 Gigabit  Ethernet interfaces
511K bytes of non-volatile configuration memory.
  and  no support  for  vrf  ...
BB1#conf t Enter configuration commands, one per line.  End with CNTL/Z
BB1(config)#ip  multicast-routing ?
BB1(config)#ip multicast-routing VRF  DIS
^ % Invalid input detected  at '^' marker.
certifiedrawi37
Hi Ehtesham,
You need supervisor 6-E for this to work.
Ahmed Alrawi
Dear Ahmed,  you are spot on !  this  is working on 6-E  , Can you give me the link please ? from where you find the info..
