multicast over a single router using VLC
rhap4boyz
I am testing a simple multicast setup using a single Cisco 1841 router with VLC.  However I cannot get it to work.  If VLCs are on the same subnet, it works.  I tried both UDP and RTP multicast to 239.255.0.1.  I tried both dense and sparse mode.  There must be something fundamental that I am missing.  I already increased the TTL in VLC but no luck.
Please help!
VLC Source -> Cisco Router -> VLC Viewer
192.168.10.200 -> 192.168.10.254 - 192.168.11.254 -> 192.168. 11.200
Current configuration : 907 bytes
version 12.4
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$.7dt$Safvc3dzyJCwubSKrJUs61
enable password 7 14141B180F0B
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
ip multicast-routing
interface FastEthernet0/0
 description $ETH-LAN$
 ip address 192.168.10.254 255.255.255.0
 ip pim sparse-dense-mode
 no ip mroute-cache
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 192.168.11.254 255.255.255.0
 no ip mroute-cache
 duplex auto
 speed auto
ip http server
no ip http secure-server
snmp-server community public RO
control-plane
line con 0
line aux 0
line vty 0 4
 password 7 13061E010803
 login
end
Jon Marshall
Your configuration looks fine to me.
It does sound like a TTL issue to me but you say you have checked that.
How are the clients connected to the router and what does the multicast routing table show ie. "sh ip mroute" ?
Jon
Jon Marshall
Jon
It turns out that the VLC GUI TTL has a bug.  Even if I specify TTL of greater than 10, it still shows TTL of 1 when using wireshark.  I end up using VLC command line which works.
Reza Sharifi
Under both interfaces, can you delete "no ip mroute-cache"
and try again?
