Multicast question - CGMP
alexng
after reading a few pdfs, the rule of thumb is, if using legacy switches use CGMP otherwise IGMP snooping is the way to go. Is that correct?
Reza Sharifi
Hi Alex,
Yes,Older boxes like 2900XL/3500XL, 2948 and 1900 support CGMP.
Here is a metrix of Cat switches that support IGMP and CGMP:
http://www.cisco.com/en/US/tech/tk828/technologies_tech_note09186a0080122a70.shtml
Reza
Reza,
Thanks, that is a very useful link!
Also, it should be stressed that the CGMP is Cisco-proprietary protocol and must be supported both by switch AND router. In CGMP, it is the router that controls the switch using CGMP. Without a CGMP-compliant router, the switch will not provide any optimized multicast delivery, and will flood all multicast packets out every port except the inbound port.
Best regards,
Peter
