Multicast routing
Desiles1011
Community Member
To have a multicasting application running in a network of Cisco routers/switches...Is only
#ip multicast-routing
enough.
Thanks in advance for all your help
purohit_810
Level 9
Level 9
What you are asking..... Multicast application in term of???
if you configure to multicast routing::::
Need following commands at least:
______________________________________________
FOR DENSE MODE ONLY
ip multicast-routing (Glocal configuration mode)
interface fastethernet (Interface in which you want to enable multicast)
ip address {IP address} {Subnet mask}
ip pim dense-mode
IN PIM SPARSE MODE
ip pim rp-address {this is the router name} {IP address}
EX: ip pim rp-address 10.10.10.1
interface fastethernet0/0
ip pim sparse-mode
You can user either dense mode or sparse mode.
Also i am attaching documet for you.
Dharmesh Purohit
