multicast RP selection
CSCO11584685
Level 3
Level 3
hi guys.
i'm facing this strange issue, where the router is not seeing/showing the priority of the RP. and hence selecting the wrong RP.
The device with issue
show ip pim rp mapping
PIM Group-to-RP Mappings
Group(s) 224.0.0.0/4
  RP 10.97.255.1 (?), v2
    Info source: 10.87.255.1 (?), via bootstrap
         Uptime: 2w1d, expires: 00:01:32
  RP 10.87.255.1 (?), v2
         Uptime: 2w1d, expires: 00:01:34
it is not showing the priority, hence it is selecting the one with highest IP. BUT the design is other way around. a working router has the following output
    Info source: 10.87.255.1 (?), via bootstrap, priority 10, holdtime 150
         Uptime: 7w2d, expires: 00:01:58
    Info source: 10.87.255.1 (?), via bootstrap, priority 20, holdtime 150
         Uptime: 7w2d, expires: 00:01:56
show versoin of the not working correctly device
show ver
IOS (tm) MSFC Software (C6MSFC-JSV-M), Version 12.1(26)E8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Fri 29-Dec-06 08:35 by hqluong
Image text-base: 0x60008F90, data-base: 0x61C8A000
ROM: System Bootstrap, Version 12.0(3)XE, RELEASE SOFTWARE
BOOTLDR: MSFC Software (C6MSFC-JSV-M), Version 12.1(26)E8, RELEASE SOFTWARE (fc1)
RCHOU505A uptime is 4 years, 47 weeks, 1 day, 19 hours, 18 minutes
System returned to ROM by processor memory parity error at PC 0x601E3954, address 0x0 at 12:57:09 UTC Wed Sep 24 2008
System restarted at 12:58:13 UTC Wed Sep 24 2008
System image file is "bootflash:c6msfc-jsv-mz.121-26.E8.bin"
cisco Cat6k-MSFC (R5000) processor with 114688K/16384K bytes of memory.
Processor board ID SAD035101KE
R5000 CPU at 200Mhz, Implementation 35, Rev 2.1
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
73 Virtual Ethernet/IEEE 802.3  interface(s)
123K bytes of non-volatile configuration memory.
4096K bytes of packet SRAM memory.
16384K bytes of Flash internal SIMM (Sector size 256K).
i Suspect it is IOS issue.
Hi Sulaiman,
The IOS you are currently use on this device is really old. I agree with you that the issue is most probably software related. I would suggest you upgrade to some more recent IOS.
Hi,would there be any document highlighting that? i tried to look but couldn't find.
