Multicasting between VRF on same switch
Hello Everyone,
I am working on Multicast scenario, There is one 6513E switch one 2960 switch. Two VRF's are configured in core switch (6513) IPTV-SRV and Villa-VRF
IPTV-SRV vrf has IPTV server and Villa-VRF has IPTV i.e. client.
VLAN 30 is mapped to IPTV-SRV vrf with subnet address 192.168.30.0/24
VLAN 12 is mapped to Villa-VRF with subnet address 192.168.12.0/24
I did the following configuration for VRF but its not working . i am not an expert in multicast design but seems i did most of the configs.
Need help in this regards,
ip vrf IPTV-SRV
rd 30:1
mdt default 232.1.1.1
route-target export 30:1
route-target import 10:1
route-target import 11:1
route-target import 40:1
ip vrf Villa-VRF
rd 10:1
mdt default 232.1.1.2
route-target export 10:1
route-target import 200:1
route-target import 30:1
route-target import 100:1
route-target import 70:1
ip multicast-routing
ip multicast-routing vrf Villa-VRF
ip multicast-routing vrf IPTV-SRV
interface Vlan12
description Villa-IPTV-VLAN
ip vrf forwarding Villa-VRF
ip address 192.168.12.1 255.255.255.0
ip helper-address 192.168.30.10
ip pim sparse-dense-mode
interface Vlan30
description IPTV-SRV-VLAN
ip vrf forwarding IPTV-SRV
ip address 192.168.30.1 255.255.255.0
router bgp 65000
bgp router-id 1.1.1.1
bgp log-neighbor-changes
address-family ipv4 vrf IPTV-SRV
  redistribute connected
exit-address-family
address-family ipv4 vrf Villa-VRF
exit-address-family
ip pim snooping
ip pim vrf Villa-VRF rp-address 192.168.30.10
ip pim vrf IPTV-SRV rp-address 192.168.30.10 override
Need some suggestions from multicast experts on the above configuration.
Thanks in Advance.
Leo Laohoo
Duplicate post #2.
Reza Sharifi
I am not sure why you have so many import statments in each vrf while you only have 2 vrfs.
Can you try leaking the vrfs together and test:
ip vrf IPTV-SRV
rd 10:1
route-target export 10:100
route-target import 10:100
route-target import 3:100
ip vrf Villa-VRF
rd 30:1
route-target export 30:100
route-target import 30:100
