multiple IP on an interface of Cisco9300
reashad
is there any way to assign 2 IPs to an interface of 9300.
i am running IOS XE 16.09.04 and sub-interface is not supported on this platform.
Jaderson Pessoa
It is possible.
Look it:
The optional secondary keyword allows you to specify an unlimited number of secondary addresses. Secondary addresses are treated like primary addresses, except the system never generates datagrams other than routing updates with secondary source addresses. IP broadcasts and Address Resolution Protocol (ARP) requests are handled properly, as are interface routes
 Physcal interface or vlan
interface GigabitEthernet 1/0/1
 ip address 192.108.1.27 255.255.255.0
 ip address 192.31.7.17 255.255.255.0 secondary
interface vlan 3000 ip address 192.108.1.27 255.255.255.0 ip address 192.31.7.17 255.255.255.0 secondary
Look documention about: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-5/command_reference/b_165_9300_cr/b_165_9300_cr_chapter_0100.html
Jaderson Pessoa
*** Rate All Helpful Responses ***
Reza Sharifi
How about using vlans? What is that you are trying to do?
