Multiple ISP / VLAN routing question
strickj
How do I route a specific VLAN(s) out a specific ISP without interrupting all of the other VLANs.
We recently installed a new ISP(B) for our public wireless network that has a 7Mb circuit. We want that VLAN to be routed to that ISP and to not use our campus 100Mb ISP(A). We do have other wireless SSIDs on the 4402 that can use our campus connection. Each SSID is on its own VLAN.
Our setup is as follows:
     VLANs --> 6509
    public wireless   rest of campus
       ASA5505          ASA5510
        ISP(B)                ISP(A)
I have tried to implement route-maps but I cannot get it to work for some reason.
Public Wireless: 10.10.192.0 255.255.192.0
Authenticated Staff Wireless:  10.10.64.0 255.255.192.0
Authenticated Stud Wireless:  10.10.128.0 255.255.192.0
Wired connections are on various segments in the following: 172.17.x.x, 172.18.x.x, 172.27.x.x, 172.28.x.x, 172.22.x.x, 172.24.x.x, 172.19.x.x, 192.168.x.x
Any assistance is greatly appreciated.
Jon Marshall
     VLANs --> 6509
       ASA5505          ASA5510
        ISP(B)                ISP(A)
Assuming the vlan you want to route via ISP B is 10.10.192.0/18 you can use PBR for this -
access-list 101 permit ip 10.10.192.0 0.0.63.255 any
route-map PBR permit 10
match ip address 101
set ip next-hop
then on the L3 SVI for that vlan on the 6500 -
int vlan
ip policy route-map PBR
Jon
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
Jon Marshall
     VLANs --> 6509
       ASA5505          ASA5510
        ISP(B)                ISP(A)
set ip next-hop
int vlan
Jon
Thanks, that's what I had but after looking at your example, I screwed up my inverse mask I had 0.0.63.0 instead of 0.0.63.255.
Thanks a BUNCH!!!!!!!!
