multiple ospf process redistribute
fly
Level 2
Level 2
   I read this document
   http://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/4170-ospfprocesses.html
  below figure 4, i have question after //
  1. Router A (Router B) redistributes M into Domain 1, and external M will reach Router B (Router A).
  2. Because the administrative distance of Domain 1 is lower than Domain 2, Router A (Router B) will install M through Domain 1 and will set to maxage its previous originated LSA (event 1) into Domain 1.//what's this LSA,the redistribute from another doman?
  3. Because M has been set to maxage in Domain 2, Router A (Router B) will install M though Domain 2 and, therefore, will redistribute M into Domain 2.  //event 2 said maxage in Domain 1 , now it is domain 2. i confused?
  4. Same as event 1.
   thank you!
Tom
fly
Level 2
Level 2
in event 2: cisco website say set maxage its previous orginated LSA into Domain 1.
but in event 3: say because M has been set to maxage in Domain 2??????
is this a mistake?
when router A receive M type 5 lsa from its domain 2,and redistribute M into domain 1,router B also redistribute M lsa,and will receive lsa from router A,because lower distance,so router B will choose lsa from router A(domain 1), and maxage its origin lsa。
so inside domain 1,only one lsa from router A exist, is that right?
but inside domain 1, which one(router A orB) lsa can exist,  we can't control
depend on the status of ospf process running?
