Multiple subnets in single DHCP pool on Cisco Device
Kyle Gatlin
3750 can not support multiple subnets in it's DHCP server pool config.
Is this an issue that can be fixed with a different iOS or is there a different Cisco switch that I can replace the 3750 with that will handle multiple subnets within an individual pool?
jonrojas
Hi Kyle,
The feature is called: "DHCP Server Multiple Subnet" and you can find more information on the following link:
http://www.cisco.com/en/US/docs/ios/12_2sr/12_2srb/feature/guide/srbmultd.html
I did a quick research on the Cisco Feature Navigator and didn't see the 3750 included on the platforms that support this feature, you can verify this yourself on the following link:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Click on "Search by Feature" and on the filter enter "DHCP" then look for the one called "DHCP - Server Multiple subnet".
