Multiple Switches?
Dmlewins1
I have two Cisco Small Business SF 100D-16 switches, one was a spare. I have run out of ports on the first one and would like to run the other one in series to new devices across the office. I'd prefer not to buy a bigger switch at the moment, but can I run one switch into the other without any adverse effect on the network.  I'm running an optical broadband connection and so far the system is fast and stable, running 8 VOIP phones, 8 laptops and 4 printers. Advice gratefully received! Thanks, Dave Lewins, The Finance Roome Ltd, Cheltenham www.thefinanceroome.co.uk for mortgage and protection advice
blau grana
Level 7
Level 7
Hello Dave,
As long as you do not create loop it should work fine.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Thanks!
