Multiple Trunk for Loadbalancer
saroj pradhan
Level 4
Level 4
please  help  me if  possible  to  implement  the  Multiple  Trunk.
My  Distribution  Switch is  3560 G and  access switch  2960. Need  two trunks carry   vlan1-10  and  if  one  fails  the other one will work as redundant.
Please advice.
Saroj
Reza Sharifi
What type of load balancer do you have?
Most support LACP and so you can put multiple links in a portchannel
