Multiple VLAN trunk on gig port
Ankit Dangwal
Hi Guys,
    I've a Cisco switch 2960G. i want to trunk multiple vlan on a single port gig0/45 without assign ip address. i already created all vlan and trunked it on a single port but its not working.
i'm using Cisco Network Assistant. please help me out.
szain
Hi Ankit,
What is the device connected to the other end?
What is the current config, please share?
What exactly do you mean when you say it is not working?
Sal
please tell me only one thing that can i trunk multiple vlan on a single port without assign them ip address?
if yes then how?
please share to me.
That should be all you need , both sides need to be set that way between the switches if your trunking between them , this will allow all vlans , youc an lock it down further with switchport trunk allowed vlan x,x,x
interface GigabitEthernet 0/45
 switchport mode trunk
end
