Nexus 7010 1/10 Gbps module not working
veevekraj
Dear friends, one nexus 7010 10G Ethernet module (N7K-F132XP-15) is not working. It was working till yesterday. After that it went down.
I checked by #show module,    It's power was down. I executed the  command #no poweroff module 3 and reload that module by command reload module 3. It's power came up but status is not OK but powered-up. I reloaded the switch but status is same.
So please help to resolve the issue. Below is the output of show module.
N7K-1#
N7K-1# show module
Mod  Ports  Module-Type                                            Model              Status
1    48     10/100/1000 Mbps Ethernet Module    N7K-M148GT-11      ok
2    8      10 Gbps Ethernet XL Module               N7K-M108X2-12L     ok
3    32     1/10 Gbps Ethernet Module                 N7K-F132XP-15      powered-up
5    0      Supervisor module-1X                           N7K-SUP1              active *
Mod  Sw              Hw
1    5.2(9a)         1.7
2    5.2(9a)         1.2
3    NA              1.3
5    5.2(9a)         2.0
Mod  MAC-Address(es)                         Serial-Num
1    00-07-7d-5d-eb-10 to 00-07-7d-5d-eb-44  JAFXXXXXXX1
2    e8-b7-48-fd-22-24 to e8-b7-48-fd-22-30  JAFXXXXXXX2
3    e8-b7-48-1f-3d-f4 to e8-b7-48-1f-3e-38  JAFXXXXXXX3
5    40-55-39-23-ab-b0 to 40-55-39-23-ab-b8  JAFXXXXXXX4
Mod  Online Diag Status
1    Pass
2    Pass
3    Untested
5    Pass
Xbar Ports  Module-Type                         Model              Status
1    0      Fabric Module 1                     N7K-C7010-FAB-1    ok
2    0      Fabric Module 1                     N7K-C7010-FAB-1    ok
3    0      Fabric Module 1                     N7K-C7010-FAB-1    ok
Xbar Sw              Hw
1    NA              1.1
2    NA              1.1
3    NA              1.1
Xbar MAC-Address(es)                         Serial-Num
1    NA                                      JAFXXXXXXX1
2    NA                                      JAFXXXXXXX2
3    NA                                      JAFXXXXXXX3
* this terminal session
N7K-1#
N7K-1#
N7K-1#
N7K-1# sh environment power
Power Supply:
Voltage: 50 Volts
Power                              Actual        Total
Supply    Model                    Output     Capacity    Status
                                 (Watts )     (Watts )
1        N7K-AC-6.0KW               664 W       6000 W     Ok
2        N7K-AC-6.0KW               657 W       6000 W     Ok
3        ------------                 0 W          0 W     Absent
                                  Actual        Power
Module    Model                     Draw    Allocated    Status
                                 (Watts )     (Watts )
1        N7K-M148GT-11              N/A          400 W    Powered-Up
2        N7K-M108X2-12L             475 W        650 W    Powered-Up
3        N7K-F132XP-15              N/A          385 W    Powered-Up
5        N7K-SUP1                   N/A          210 W    Powered-Up
6        supervisor                 N/A          210 W    Absent
Xb1      N7K-C7010-FAB-1            N/A           60 W    Powered-Up
Xb2      N7K-C7010-FAB-1            N/A           60 W    Powered-Up
Xb3      N7K-C7010-FAB-1            N/A           60 W    Powered-Up
Xb4      xbar                       N/A           60 W    Absent
Xb5      xbar                       N/A           60 W    Absent
fan1     N7K-C7010-FAN-S             76 W        720 W    Powered-Up
fan2     N7K-C7010-FAN-S             76 W        720 W    Powered-Up
fan3     N7K-C7010-FAN-F              8 W        120 W    Powered-Up
fan4     N7K-C7010-FAN-F              8 W        120 W    Powered-Up
N/A - Per module power not available
Power Usage Summary:
Power Supply redundancy mode (configured)                PS-Redundant
Power Supply redundancy mode (operational)               PS-Redundant
Total Power Capacity (based on configured mode)               6000 W
Total Power of all Inputs (cumulative)                       12000 W
Total Power Output (actual draw)                              1321 W
Total Power Allocated (budget)                                3835 W
Total Power Available for additional modules                  2165 W
N7K-1#
N7K-1#
N7K-1#
Mark Malone
It sounds as if its hardware failed and needs to be replaced , the only other option is to try re-seat it and see if that fixes it and run diag on it
diagnostic start module x test
show diagnostic result module x
