Multiple vPC peer links between two Nexus 9K
Gianluca Renzi
my question is pretty simple: is it possible to configure two (or more) vPC peer links between the two switches belonging to a vPC domain? The purpose is to configure a vPC domain where two different peer links are used to carry different VLANS, instead of having a single peer link for all the VLANS (see attached image).
Thanks in advance
Its not supported.
If you are concerned about bandwidth add more links to Peer link.
Madhu
Its not supported.
Madhu
