Multiple wireless VLAN issue
jessica_s
Community Member
I'm pretty new to Cisco products and I'm trying to configure a public guest wifi. I looked at numerous tutorials but mine just does not seem to work. I have my wired and Vlan1 wireless just fine. Just can get Vlan2 to work. If anybody could help me with this problem I would greatly appreciate it!
Sandeep Choudhary
Please see this document.
https://supportforums.cisco.com/docs/DOC-16145
Please rate if it helps.
Thank you for the reply, but unfortunately I've already seen that document. I'm starting to think my problem has something to do with the authentication methods my router is using. I think the guest wireless can't authenticate because I have the wireless authenticating against a radius server using EAP protocols. Is there a way to get the guest wireless to not have to use EAP protocols or the radius server while the work wireless still uses it?
